Discussion topic: Recent frequent disconnects
Message posted on 14 Mar 2024 07:31 PM
Hi, I have been with sky broadband for a very long time and always sync at full speed (80 down 20 up). This connection over the years has been mostly rock solid however recently I am encountering multiple disconnects every day and the reconnect always seems to result in reduced speed.
Stats are below
This is becoming annoying as I work from home and at the moment dont feel that I can rely on this connection any longer. I have never had disconnects like this from this line before.
Message posted on 15 Mar 2024 07:24 AM
Re: Recent frequent disconnects
@AndyStubbs the stats dont tell us very much as the hub was restarted just before you took the stats. If the hub is not restarting on its then it is likely to be faulty but if you restarted it yourself that doesnt apply.
Line drops on copper lines are not uncommon especially in periods of bad weather and Openreach are often reluctant to take action as their automatic DLM system is designed to intervene dropping speeds slightly by increasing the noise margin and improve stability. There are signs that is happening on your line as speeds are slightly below 80Mb/s and the noise margin is slightly high at 6.4dB but likely to be well abovecthe guarantee.
It is only where that system cannot stabilise the line without dropping speeds below the guaranteed speed for the line or drops exceed 10 a day that Openreach will definitely accept a fault report from their customer Sky. These are the SLA for domestic lines you are buying, the fact you use the line for business doesn't change that unfortunately. It is worth reporting the issue to Sky if you do try to use the Sky Talk line as if that is crackling Openreach will be more willing to sort the issue. Dialling 150 on that line gives you a free call.
Message posted on 23 Mar 2024 05:29 PM
Something is now clearly wrong with this line. I have disconnected again and have the following stats..
Please note that prior to this my service would maybe drop out at most once a year and usually resync at 80 / 20.
As I have recently switched to sky stream I am now reliant on a stable connection so if this continues I will be looking to cancel stream on the basis that sky cannot provide me with a stable connection.
Message posted on 23 Mar 2024 09:27 PM
And yet another drop out and reconnect...
Message posted on 23 Mar 2024 09:42 PM
Ours is exactly the same constantly keeps dropping wifi,it's absolutely ridiculous
Message posted on 23 Mar 2024 09:51 PM
@AndyStubbs if your hub is restarting on its own it is likely to be faulty so call Sky to get it replaced.
Message posted on 23 Mar 2024 09:53 PM - last edited: 23 Mar 2024 09:56 PM
The hub is not restarting - the connection drops - ie middle light goes out, takes ages to reconnect and then speed is reduced. I have always had a rock steady 80 / 20 connection and no disconnects but recently I get frequent disconnects and am unable to get the speed I had before.
It is now unreliable and not fit for streaming TV so I need it sorted or I will be sending teh sky stream devices back
Message posted on 26 Mar 2024 03:04 PM
Everytime you have posted your stats the hub is showing a low uptime (a few mins) this means its useless to us. If you say your hub is not restarting on its own then are you doing it before you post your stats? If so why?
Message posted on 26 Mar 2024 03:52 PM
Because in the past on the very few rare occassions that I had an issue a reboot solved it.
Message posted on 26 Mar 2024 03:56 PM
Are you still seeing multiple drops per day or has it slowed down?
Can you please post your stats after the next time it drops before you reboot it.
Message posted on 30 Mar 2024 09:41 AM
Dropped again just now. Stats below/
Message posted on 31 Mar 2024 08:09 AM
And again last night...
Message posted on 31 Mar 2024 08:25 AM
@AndyStubbs as I posted before copper lines can be unreliable especially during periods of bad weather and the very wet winter has caused loads of issues. Unfortunately it is unlikely Openreach would consider under 10 drops a day as a fault. Why your line has become less stable is not clear but given Openreach are increasingly unwilling to spend money on the copper network I think this something you will have to live with until they install full fibre in your area.
Message posted on 01 Apr 2024 09:13 AM
And again this morning...
Message posted on 02 Apr 2024 10:15 AM
The slight changes in line sync speed as well as the router running at 6dB rather than an optimised 3dB suggests the line isnt quite happy. However convincing Openreach to look at it when its only a couple drops per day may be challenging. Your best bet is likely to call Sky during a time it usually drops or right after its dropped.
