Discussion topic: Re: what number do I need to speak to a real person at sky TV
This message was authored by: Janet93
I am trying to get help with my boat band I need an engineer out
@Janet93  An engineeer won't be sent out on the back of a community post, no one at Sky will know who you are from your login.
If you require help you need to explain what the issie is with your Broadband
@Janet93  What is the issue that you are having with your broadband. The communit needs a little bit more information in order to help you.
@Janet93
What problems are you having, is it running slow or not working at all, if the later try this:
The first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
