Discussion topic: Re: Sky Broadband Hub Awaiting Dispatch
This message was authored by ImDaPandaNow This message was authored by: ImDaPandaNow
Order now says its been cancelled after phoning them they say they can't do anything until tomorrow to replace the order. This is completey unacceptable by sky no contact until calling today and being passed between 5 different departments plus an unpaid day off work for an engineer not showing up. Disgusting customer service.
This message was authored by spencerdalby1 This message was authored by: spencerdalby1
Openreach engineer can always complete work without the broadband router
if an engineer cant complete the work its usually a fault with openreach not the isp itself
that been said, once your broadband goes active which is usally 24 hours after the engineer has completed his work, you can call sky and get a new router
sky can only issue new routers once the broadband has gone active.
Hope this helps
Let me know if you need a hand with anything else
and drop me a like if you have found this useful
