2
This discussion topic has been answered Discussion topic: Re: No internet connection
This message was authored by: Julia91
The Internet green light on my router is not on
@Julia91
@Julia91
@Julia91  First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Please be aware that outages after midnight are usually down to maintenance, please see this pinned post https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
If your ONT shows a Red Light please see this guide https://helpforum.sky.com/t5/Broadband-Talk/Can-t-connect-to-broadband-and-have-a-red-light-on-your-...
