Discussion topic: Re: No Satellite Signal (But Sky Q says signal locked on 90%)
This message was authored by: g.norris1
No Whif all day yesterday and still no Wi-Fi
Avatar for g.norris1
Have no Wi-Fi since yesterday and not on again today
@g.norris1
You've added to a thread on the Sky Q board about no satellite signal?
Wi-Fi is basically the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
