10 Nov 2022 04:47 PM
Hello please can someone help me re-book a engineer appointment to come and set my internet please?
10 Nov 2022 04:50 PM
Posted by a Superuser, not a Sky employee. Find out more@Fran+Radu You would need to call into Sky to do this, I cannot be done via the forum.
10 Nov 2022 04:59 PM
I called but they say they can't help me ?
10 Nov 2022 05:06 PM
Posted by a Superuser, not a Sky employee. Find out more@Fran+RaduWhat do you mean by setting it up? Do you mean plugged it in from when the router is in the box to where it works and gives you an internet connection? Or is this to do with setting up your connection as you do not have one?
10 Nov 2022 05:15 PM
Erm I have virgin media and I tried to cancel it and change to sky broadband but no one helps me
10 Nov 2022 05:35 PM
Posted by a Superuser, not a Sky employee. Find out more@Fran+RaduYou should be able to order Sky broadband when it is installed then you can cancel Virgin.
10 Nov 2022 05:39 PM
I already have the sky broadband I just need a engineer to come and set everything up
10 Nov 2022 05:46 PM
Posted by a Superuser, not a Sky employee. Find out more@Fran+RaduThis is a self install. The instructions come with the router on how to install it.
10 Nov 2022 06:11 PM
I know but we have sky and the engineer came and said that we need to drill outside and change from virgin media to sky broadband but I don't know what to do because it won't let me re-book a appointment?
15 Nov 2022 10:46 AM
Posted by a Superuser, not a Sky employee. Find out moreIf you require drilling to setup an Openreach line then you dont yet have Sky broadband. You'll need to call Sky and ask for an update on where they are at with the install.
17 Nov 2022 10:06 PM
I have sky broadband I just need sky activation
