Discussion topic: RED LIGHT
Message posted on 29 Aug 2026 10:53 PM
RED LIGHT
Message posted on 30 Aug 2026 12:38 AM
Re: RED LIGHT
@Malc61yabass
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
(this won’t necessarily identify a fault just affecting your address).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
