Discussion topic: Puck not working
This message was authored by: Jazz29
Puck not working
The streaming pucj isn't working
Re: Puck not working
You have not mentioned what is not working or what you have tried.
If it's some kind of intermittent error while watching content, try a settings restart.
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Stream puck will perform a reboot. It will take a few minutes to complete
If it's not turning on. This is normally when the puck gets stuck in a standby state.
Have a read of this article, namely performing the recovery procedure on step 4;
https://www.sky.com/help/sky-tv/sky-tv-glass/fixing-a-problem-sky-glass/fixing-sky-glass-sky-stream-...
