Discussion topic: Ps5 no longer connecting
This message was authored by: Chelsea135
Message posted on 26 Jun 2026 11:54 PM
Ps5 had been connected to new WiFi, nothing has moved and now it's not longer connecting saying ssid incorrect when it is all correct
Find out more
Message posted on 27 Jun 2026 05:33 AM
Re: Ps5 no longer connecting
If you are seeing an error about entering the wrong Wifi password then make sure you are not getting a 1 and l or a 0 and O muddled as it is quite easy to do this. It must also be entered as shown on the hub itself so use upper case letting if required.
