Discussion topic: Programmed keeps frozen
This message was authored by: gary+crosbie
Broadband keeps freezing everyone on the telly or on the Xbox either if you go on to iPlayer or anything like that it does keeps freezing and then you go on YouTube on the Xbox is to say he's the same on a TV
Re: Programmed keeps frozen
Have you power cycled the hub/router (i.e. pulled the plug for at least 5 minutes), before rebooting?
What does the service checker in My Sky tell you?
sky Q | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
