Discussion topic: Programme loading error message and no signal for tv
Message posted on 28 Jul 2026 06:30 AM
We are having trouble watching any live tv and it lags and freezes can I please have a booster sent out for the WiFi I have tried all the steps and we even had a new streaming puck
Message posted on 28 Jul 2026 07:53 AM
Re: Programme loading error message and no signal for tv
No, as we are customers we can't send out anything to you https://helpforum.sky.com/t5/Members/ct-p/members
You'll need to call Sky for that.
These are the current methods for contacting Sky. (Depending on your reason for making contact some methods will be more appropriate than others) …
🔶📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Note: if your services are restricted due to a missed payment phone contact is unlikely to work.
🔶online help via this link
https://www.sky.com/help
🔶 Sky Assistant should also be available via
🔶Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
Note If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required.
