Discussion topic: Program Loading Issues
This message was authored by: IanLacy
Having problems getting a program to load. No matter what channel I try I get a "technical error loading" message. Any suggestions? I have gone through the diagnostics on the sky app it nothing has worked.
Re: Program Loading Issues
@IanLacy whst Sky TV servicecare you using Sky HD+, Sky Q, Sky Stream or Sky Glass as each is different?
Avatar for IanLacy
Hi there, it's the sky puck streaming.
It started yesterday afternoon, I can:
1 turn it on
2 it loads up like normal
3 once I try and select any channel it brings up an error message. " there is a technical fault with this program" it shows the same message for any channel I choose!!!
i have tried the following:
1 looked at the sky app and followed the diagnostics
2. Still no good
3. I have run a speed test on the broadband - all good plenty of speed
4. checked and verified the tv is connected to WiFi no problems with that ( I can use my fire stick and other streaming apps)
don't know what else to do apart from call sky?
thanks.
