Discussion topic: Problems with wifi
This message was authored by: smithy23245
Problems with wifi
Theres a problem with my wifi
Re: Problems with wifi
@smithy23245
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
