Discussion topic: Problems with wifi
Message posted on 23 Jul 2025 09:40 AM
Problems with wifi
I work from home and cannot use Teams/Google meet - the calls keep dropping out. It often freezes when I am working. It is unreliable. I may lose my job if I don't have a consistent service. This is causing massive stress.
Message posted on 23 Jul 2025 10:27 AM
Re: Problems with wifi
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
Message posted on 23 Jul 2025 11:39 AM
Unfortunately I still have the issue, even though the checks show clear. I can't get hold of anyone at Sky. Thank you for your suggestion though. I need to speak to someone at Sky who can help!!!!!.
Message posted on 23 Jul 2025 01:39 PM
@AMHARROP - are you currently connected via Wi-Fi? If so, switching to a wired Ethernet connection could significantly improve stability and help reduce some of the stress and risk you're facing with work disruptions.
