Discussion topic: Problems with connection
This message was authored by: Nicksha
Connection keeps dropping
Re: Problems with connection
@Nicksha
Even if you’ve already tried it use this link to check if there are any broadband issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
▪️I AM NOT A SKY EMPLOYEE ▪️
