Discussion topic: Problem
Message posted on 28 Jul 2026 04:53 PM
Problem
Every time you the tv is switched on it says no Wi-Fi and my phone has no Wi-Fi 3 rooms from the router. I have to reconnect every time
Message posted on 28 Jul 2026 06:04 PM
Re: Problem
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
