Discussion topic: Problem with wifi
This message was authored by: Hani2
Message posted on 07 May 2026 02:50 AM
Problem with wifi
Hi, I don't know if I've been hacked or what but I keep getting told to go to myrouter.io? I don't know why though
Find out more
Message posted on 07 May 2026 09:55 AM
Re: Problem with wifi
What broadband hub do you have, if it is the Max hub then you should be able to use the MySky app instead to acecss the hub settings.
