Discussion topic: Problem with wif connection
This message was authored by: Stevie137
I was upgraded to fibre option yesterday. The broadband router had to be moved and now my central heating device tells me that's it's offline. Engineer yesterday suggested that I may need a booster
Re: Problem with wif connection
@Stevie137 Best if you can look to put the sky Hub back to where it was before if possible with the purchase and run off a longer Ethernet cable.
