Discussion topic: Problem with wi fi we are using mobile to watch TV
This message was authored by: Gosia75
We have problems with wo fi currently connecting TV to our mobiles to have an access to the Internet our router is about 6 years old if not more
Re: Problem with wi fi we are using mobile to watch TV
@Gosia75 the age of your Sky hub should not be an issue as long as it isnt the type on the second line in the picture on this page https://www.openreach.com/fibre-checker
You do need a relatively strong Wifi signal to stream video however decent bandwidth is only half the story as stability is just as important. First thing to check is the position of the hub which should be in the open on a surface so its above obstructions like radiators. It is worth rebooting th hub by removing the power for a few seconds as that will cause it to find the least congested wifi channel.
Newer hubs while having new functions do not have much greater range - the power they can use is limited by regulation. In many homes you need more than the free router any isp can provide. There are loads of third party solutions and Sky sell add-on packages like Wifi Max which can have up to 3 extenders.
