Discussion topic: Problem with the WiFi it keeps cutting off
Message posted on 21 Jun 2026 07:40 PM
Message posted on 21 Jun 2026 07:44 PM
Re: Problem with the WiFi it keeps cutting off
@Ka12makwjwj
You may not be aware but you haven’t contacted Sky by posting here. This is a customer ▶️ customer discussion forum where we try to assist other customers.
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
