5
This discussion topic has been answered Discussion topic: Problem with sky wifi extender/ booster
This message was authored by: jeidnfieoejrir
Hi we have 2 sky wifi  extender/ boosters and we should have 3 green lights on each when working correctly, however we only have 2 green lights lit on both boosters. One is the power light, the other is the WiFi light however the middle connected light is not lit on both the boosters.
can some one please help
thanks
Avatar for jeidnfieoejrir
This message was authored by: jeidnfieoejrir Answer
Re: Problem with sky wifi extender/ booster
Thank you so much for your help and the link you so kindly suppied, we have hardly any technical knowledge but thanks to your post we have managed to get them both working again. Thanks again
@jeidnfieoejrir Does you sky Hub have an Internet connection, if it is down then the extenders will be also.
We our sky hub has a internet connection
Sorry I meant yes our sky hub does have a internet connection
@jeidnfieoejrir So have both the boosters just lost the middle light's, if so just disconnect move down to the hub within a couple of feet, power it back on again and see if the light comes back on. Let me know how that goes first?
Edit:- if no joy then we are going to reset only the booster's and re-pair to the hub again, copy of the help link will be below.
https://www.sky.com/help/home/broadband/sky-broadband-equipment/sky-wireless-booster/articles/sky-wi...
