Discussion topic: Problem with Wi-Fi
This message was authored by: Traytel2005
Problem with Wi-Fi
We have recently had fibre installed into our home.. dispite it was problematic with twice installation.. and moving our hub in our dining room.. we are having trouble with a strong connection.. in our lounge which is situated at the back of the house.. we had a booster that apparently is no longer required.. .. now since this now up and running.. our signal is very weak..
can you help asap
Re: Problem with Wi-Fi
@Traytel2005 If you need and want help then a call to sky is the best way! contact details are below! The new position has changed all the dynamic off the Wireless Wi-Fi so best sky advise you what is required now!
https://www.sky.com/help/page/broadband-digital-hub
