Discussion topic: Problem with Broadband
Message posted on 28 Jun 2025 10:16 PM
We keep having problems with our broadband, right now it's stating it's not connected and that there seems to be a problem with your broadband but the tests I've done through the app says there isn't a problem- the sky stream tv is connected broadband router but not connected to the internet
Message posted on 28 Jun 2025 10:21 PM
Re: Problem with Broadband
If you haven't done this yet then try a reboot of yor broadband hub at the mains. If you staill have no access then try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
