Discussion topic: Problem connection
This message was authored by: Julienesbit
Problem connection
My wifi connection goes down several times a day
Re: Problem connection
@Julienesbit Have you tried or checked the following, see the link below!
Try running the line test here to see if any faults are found:
If you wish also see the link below and say what you see from that!
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
