Discussion topic: Power problem
Message posted on 26 Aug 2024 08:01 PM
Power problem
My WiFi box has gone down it's persistently flashing amber on power, I've tried reset and taken all wires out and back in on & off and no luck
Message posted on 26 Aug 2024 08:30 PM
Re: Power problem
@Kerry98 Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
