Discussion topic: Possible issue with upgrade
This message was authored by: J0rdM
Hello all,
I've made the upgrade to Full Fibre Gigafast wifi and have recieved my convertion kit, however I have realised that my hub has to be located in the bedroom due to the Microfilter being there. Will this cause an issue when the engineer comes to install the Face Plate and do all their wiring etc?
I live in a ground floor apartment and is surrounded by bushes so I'm not sure if they will be able to install everything
Anyone had something like this before? How was it rectified?
Re: Possible issue with upgrade
@J0rdM
For gigafast fttp the location of the old mastersocket does not necessarily mean the fibre ont will be installed in the same location.  Have a word with openreach to discuss your preferred location
Avatar for J0rdM
Am I best to do this in advance or the day they arrive?
@J0rdM
You would speak to them on arrival unfortunately.
Microfilter and Face Plate are only relevant to broadband over copper: Gigafast has to be full fibre, with an optical bearer cable and an ONT ('fibre modem')
https://www.openreach.com/help-and-support/full-fibre-broadband-installation-checklist
Avatar for J0rdM
Ah so am I right in believing that my hub will be moved to where the ONT will be fitted?
@J0rdM
By default, yes, because ISPs only supply a short ethernet cable to make that connection.
