Discussion topic: Port forwarding on ER115
This message was authored by MattyRichardson95 This message was authored by: MattyRichardson95
Hey, first time posting sorry if this has been answered but searching doesn't seem to return any results.
Basic need but cant find a simple solution, I would like to use port forwarding to achieve the following:
Forward port 4200 -> 22
Am I missing something really obvious?
Thanks in advance!
Re: Port forwarding on ER115
@MattyRichardson95 follow the instructions here to set up,port forwarding on your hub. You are normally forwarding incoming traffic using that firewall port to a specified device on your network.
When testing the set up the device must be running an application that will respond to the port probe or it will look to be still closed.
MattyRichardson95
Hi thanks but that doesn't seem to solve my issue in the way I wanted
I have found a workaround (being not using the sky router to manage this)
The Sky hub doesnt support port mapping only forwarding from the same external > internal port.
I am NOT a Sky Employee
