Discussion topic: Port Forwarding with two routers
Message posted on 03 Apr 2024 11:50 AM
Hello guys, I was wondering if anyone would be able to assist with setting up Port Forwarding on my Sky router.
I have a second router connected (via ethernet) to Sky and the internet is working fine.
Next, I need to setup Port Forwarding on the Sky Router to allow Router 2 to connect to this router via a VPN server when I'm outside the home network.
I've searched the internet and found articles on setting up Port Forwarding with Sky routers but I was running into trouble setting it up and this article is from 2017 so some of the steps seem different when I log into my Sky hub.
Any help setting this up (from the Sky router) would be much appreciated.
Message posted on 03 Apr 2024 12:26 PM
Re: Port Forwarding with two routers
@mikebali Why are you using 2 routers? You're asking for complications doing this, just use one router and then access points or network switches to expand your network.
Message posted on 03 Apr 2024 12:43 PM
Thanks for the reply. This is the way I need it setup.
Would you know how to setup this port forwarding?
Message posted on 04 Apr 2024 12:00 PM
I've opened a port of Sky and added the firewall rule but when I test to see if the port is open it says it's closed. Any idea why this might happen?
