Discussion topic: Poor wifi
This message was authored by: Habib4
Poor wifi
The WiFi signal to my sky stream box is poor.
Re: Poor wifi
@Habib4
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Alternatives are homeplugs or your own mesh network.
Avatar for Habib4
Level 0 icon
Re: Poor wifi
Thanks for the quick reply. That was my thought re re the pods, but just wanted to check how I go about that.
