Discussion topic: Poor wifi
This message was authored by: Tm35
Message posted on 06 Aug 2026 11:37 AM
Poor wifi
I'm having a very poor connection in a couple of my rooms
Find out more
Message posted on 06 Aug 2026 12:18 PM
Re: Poor wifi
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Alternatives are homeplugs or your own mesh network.
