Discussion topic: Poor wifi signal
This message was authored by: Matt872
Poor wifi signal
Test showing wifi is good but having issues with all devices. Devices keep dropping out and not working properly. There was lightning in the area a few days ago.
Re: Poor wifi signal
@Matt872
A poor signal in certain rooms is something that comes up on here on a regular basis so try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
