28 Jun 2023 07:28 PM
What i shuld to do ? upload speed less than 0.5mb/s
28 Jun 2023 07:36 PM
Posted by a Superuser, not a Sky employee. Find out more@Anonymous
Have you checked if you can upgrade?
The upload on a 24Mbps line should be around 1.5Mbps but is not guaranteed
Your only hope on your current would be to claim you are under ofcom uso of 1Mbps
Also can you enter your full postal address below and post the table after removing your address from the image
28 Jun 2023 07:48 PM - last edited: 28 Jun 2023 07:49 PM
As @cookiemonsteruk indicates, you're using ADSL broadband which is now essentially obsolete in part due to the very low maximum upload speed inherent to the technology. You'd want to be looking to move to FTTC, G.fast or FTTP.
