3
This discussion topic has been answered Discussion topic: Poor speeds for Full Fibre
This message was authored by: kevtur2000
When first installed I got between 145-150 download and upload. Now a few months on and a couple more people with Sky Full Fibre down my road I only get between 15-20mbps.
T
his can't be normal surely?
Re: Poor speeds for Full Fibre
@kevtur2000 the fact that your Ethernet speds are still in the normal range implies the issue is poor WiFi speeds in your home. WiFi conditions vary due to multiple factors.
One is interference from neighbours' networks simoly rebooting your hub can help,as the hub will,choose the least congested WiFi channels. Another is positioning many homes have areas with poor WiFi signal due to the layout of your home. Ensuring the hub is out in the open away from other electrical equipment and on a surface above radiators can help. However improving your WiFi coverage often requires addition of extra sources like Sky's WiFi Max pods or buying your own equipment.
@kevtur2000  What speeds do you get with an ethernet connected device?
Avatar for kevtur2000
For an Ethernet device I get 125-140 download and 145-148 upload
