Discussion topic: Poor speed
Message posted on 09 Feb 2026 03:43 PM
Poor speed
Message posted on 09 Feb 2026 04:05 PM
Re: Poor speed
@Marilyn__ Not much wrong with those figures that you have posted, check your own line from below!
And if needed this below!
Try running the line test here to see if any faults are found:
