Discussion topic: Poor signal
Message posted on 30 Jun 2026 03:14 PM
Poor signal
The last couple of days the WiFi signal has got weaker resulting in lost connection. Where the signal was fine it is now struggling
Message posted on 30 Jun 2026 06:27 PM
Re: Poor signal
A poor signal in certain rooms is something that comes up on here on a regular basis so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
