Discussion topic: Poor signal
This message was authored by: Oliver771
Poor signal
Tv picture keeps glitching and then goes blank. Re set it fine for a bit and then same again! Daughter keeps moaning the internet is dropping off her phone too!!
Re: Poor signal
@Oliver771
Try running the line test here:
If this is of no help give Sky a call to report it to them.
Avatar for Oliver771
Re: Poor signal
Thank you,  unfortunately continued to be poor for the rest of the evening even though the tests were all green. Seems to be back to normal now though.
