Discussion topic: Poor signal strength
This message was authored by: LeeF43
Message posted on 10 May 2026 10:04 PM
We recently had engineers fit a new router but as its in the front porch we now have no signal in the back bedroom or garden. It was better before this supposed upgrade.
Find out more
Message posted on 10 May 2026 10:07 PM
Re: Poor signal strength
A poor signal in certain rooms is something that comes up on here on a regular basis so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
