Discussion topic: Poor / no wifi connection.
This message was authored by: Kathrine0412198
Message posted on 16 Jun 2024 08:24 PM
Internet connection keeps dropping out, devices aren't connecting to WiFi. I have used the app to see if there's an issue but it doesn't detect an issue even though the lights on the hub keep going orange.
This message was authored by: mae-3
Message posted on 17 Jun 2024 02:52 AM
Re: Poor / no wifi connection.
Which lights go flashing orange/amber is it the internet light? If so then you may have an internet fault but it needs to fail at least 10 times in a day or fail for an extended time before Sky considers it a fault.
Recommend you keep an eye on it and if it fails more than 10 short drops or more than an hour length you contact Sky for an explanation, so Sky can assign an engineer when necessary to fix the fault.
