Discussion topic: Poor hub connection
Message posted on 15 May 2025 08:14 PM
Poor hub connection
Message posted on 16 May 2025 07:58 AM
Re: Poor hub connection
@Gazzza is the checker reporting sn issue with the connection to your hub or with WiFi in your home? The former needs Sky's help so call them. The latter though is very common indeed poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Message posted on 17 May 2025 09:19 AM
Thank you. I've signed up to Sky Max. Do they send the extenders automatically or do I have to request them? Thanks.
Message posted on 17 May 2025 09:40 AM
@Gazzza You need to call, they will run a test and from that the decission about the first one is made. Link below to the number just click on the need more help to see it. Also all the max info if you wish to look.
getting sky max and how to get the pod's
https://www.sky.com/help/articles/sky-wifi-booster-what-do-you-need-help-with
https://www.sky.com/help/articles/enhanced-wall-to-wall-wifi-guarantee
