Discussion topic: Poor fiber
This message was authored by: WUBS01
Poor fiber
I've run speed test on my new fiber. Ment to be 151.. I'm getting 91.5 Though your app it reads 151.. Through the app speed test your engineer gave me says 91.5 Please increase or can I have an engineer out Regards Steve
Re: Poor fiber
@WUBS01  Which kind of device was this speed test being done and how is it connected to the router?
Avatar for WUBS01
Re: Poor fiber
New sky router installed last week.
Ps5 connected via ethernet cable.
Computer/pc via ethernet cable
Ran a speed check on both 91.5 ment to be 151.
On sky app it shows correct speed..
Which I don't believe is true as my other device all say the same 91.5
Re: Poor fiber
@WUBS01
If this is on a pc check and change your ethernet card settings
to check what speed your card is currently set to :-
Go to the icon of the taskbar
Locate the icon Internet
Press on network and internet settings
Click on Ethernet
Click change adapter options
Double click on Ethernet. There, you get the speed, it can be 100 mbps or 1Gbps. If it is the second, we do not have to do anything, but if it is the first we have to configure the card
Then If you have a windows pc you can change the card settings as below
In the window where the speed was indicated, you have to click on properties
Check that the option Microsoft network clients is marked, if not, do it
Click on set up
We go to Advanced Options
Search Speed ​​& Duplex
Change the value to 1.0 Gbps Full Duplex
Accept
Also check the sky hub settings to make sure ethernet is set to gigabit
Avatar for WUBS01
Re: Poor fiber
What about ps5
Re: Poor fiber
@WUBS01
Should already be gigabit
Log onto your router by entering 192.168.0.1 in the address bar of a browser and click on ethernet.
Enter
Username     admin
Password       wifi password
Make sure ethernet is gigabit and not fast
Re: Poor fiber
@WUBS01
Sounds like your using ethernet cables that haven't got all 4 pairs wired up. These are often cheap ones bundled with products.
I am NOT a Sky Employee
