Discussion topic: Poor connectivity in side extension
This message was authored by: RAlien
Hi. I have an extension on the side of our home and thr connectivity is weak there. I was able to create a mesh system with my old wifi devices. Please can you provide an extender or something to cover the dead spots in my home. Thanks.
Re: Poor connectivity in side extension
@RAlien
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
