Discussion topic: Poor connection
Message posted on 29 May 2025 08:13 PM
							Poor connection
Message posted on 29 May 2025 08:16 PM
							Re: Poor connection
Message posted on 29 May 2025 08:41 PM
							Re: Poor connection
@Raph12 Is it only the iPad with the problem, how do you know it's a poor connection?
Message posted on 29 May 2025 08:45 PM
							Re: Poor connection
Yes only Ipad. I did WiFi check and all others devices were fine
Message posted on 29 May 2025 08:50 PM - last edited: 29 May 2025 08:50 PM
							Re: Poor connection
@Raph12 Is it the first time that the iPad has been on the sky network, have you switched off the iPad since you connected it, unless the iPad has jumped onto the lower frequency band it should be up there, you do not even say what speed you have with it so is it just low number off bars, does it go quick when you go near the hub???
