Discussion topic: Poor connection in one room
Message posted on 28 May 2026 09:50 AM
The back room in the house as a poor connection to television and I pads and phones. Just had new router and stream subscription
Message posted on 28 May 2026 10:30 AM
Re: Poor connection in one room
A poor signal in certain rooms is something that comes up on here on a regular basis so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
