Discussion topic: Poor connection during ms team calls
This message was authored by: Andyphoenix
Poor connection speeds on work calls . Calls blurring and sound dropping out . Pc connection to the router via cables
Re: Poor connection during ms team calls
@Andyphoenix you should not hit issues with Teams with a PC connected by a direct Ethernet cable to the hub unlike WiFi. Teams need minimal bandwidth to operate but is sensitive to instability are there multiole other users of the connection while you are calling? Do other devices behaving normally?
