Discussion topic: Poor conection wifi
This message was authored by: Rhiannoncleasby
Message posted on 28 Sep 2025 09:36 PM
Poor conection wifi
Ive had poor connection over this past week really poor to the point where I can't even load a video the connection keeps dropping and everything lags when it does work
Message posted on 28 Sep 2025 10:04 PM
Re: Poor conection wifi
@Rhiannoncleasby What sky hub do you have, and you can 1. run the diagnostic so see if anything is found, and tonight if not using the sky Hub switch it off going to bed and back on in the morning!.
Try running the line test here to see if any faults are found:
