Discussion topic: Poor broadband
This message was authored by: -Grant_14
Poor broadband
Very spotty connection over the last week, and now have no WiFi at all, yet the service checker on the app says everything is good. I'm trying to work from home, and the kids are at home because it is the school holiday, so no WiFi is a disaster! I've still got lots of time on my contract, but this is the kind of unreliable service the encouraged me to leave virgin
Re: Poor broadband
@-Grant_14
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
Avatar for -Grant_14
Re: Poor broadband
Thanks. Tried all those things and it kept saying everything was fine. It did seem to resolve itself after a few hours, with all devices working fine since. Still no idea what the problem and subsequent cure was
