Discussion topic: Poor broadband speed
Message posted on 26 Sep 2026 09:31 AM
Message posted on 26 Sep 2026 09:49 AM
Re: Poor broadband speed
Having the same problem!
Message posted on 26 Sep 2026 09:57 AM
Do you have a telephone number so you can speak with a real person
Message posted on 26 Sep 2026 10:37 AM
@K_S_ wrote:
My broadband speed keeps dropping from 150mb to about 10mb
Broadband, or WiFi?
Message posted on 26 Sep 2026 12:29 PM
Erm! Not sure when I do a speed check on fast.com I regularly get speed of 8 to 40 mbps not the 150 I should be getting. I have a Sky max hub
Message posted on 26 Sep 2026 12:50 PM
@K_S_ wrote:Erm! Not sure when I do a speed check on fast.com I regularly get speed of 8 to 40 mbps not the 150 I should be getting. I have a Sky max hub
Use the MySky app and have a look at the broadband section, it will tell you the speed you're getting to the hub. If this is OK then it's probably a device connecting via wifi and there's no guarantee on that speed due to the many, many variables involved.
Not a Sky employee
Sky FTTP 500Mb to Max Hub
Message posted on 26 Sep 2026 03:29 PM
150Mbs is speed delivered to the Hub over optical fibre and ethernet cable, not WiFi from it. If you are accessing fast.com on a wireless device then you aren't testing the Hub speed.
