Discussion topic: Poor WiFi
Message posted on 07 Sep 2026 09:19 AM
Poor WiFi
Our WiFi keeps dropping off and Netflix keeps buffering. We have a ring doorbell that can't keep connection either. We've upgraded to Max and it still hasn't improved. There's only one room in the house that the connection is okay in and it's the room that the box is in
Message posted on 07 Sep 2026 10:22 AM
Re: Poor WiFi
A poor signal is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Alternatives are homeplugs or your own mesh network.
