Discussion topic: Poor WiFi
This message was authored by: LaineSky
Poor WiFi
Hello. I have very poor wifi since i started to use sky. Cant open properly Facebook. If i try to send messeges in Facebook messenger,sometimes its stays unsend. Even my work app doesnt work properly need to wait couple minutes till its opens my rota etc.
Re: Poor WiFi
@LaineSky therecare mulyiple reasons why apps take time to load. Toncheck if it is the WiFi signal strength run a test on Fast.com if thstvshows speeds below 10Mb/s you need a booster to improve the signal in the room you are in see https://www.sky.com/help/articles/sky-wifi-max
However if the WiFi is not the issue the speed apps take to load can be down to other factors not linked to your broadband. These include server delays or thecsecurity siftware on the device.
