Discussion topic: Poor WiFi
This message was authored by: Scott248
Poor WiFi
We can't get wifi around all of my house , we used to but something has changed !!!
This message was authored by: Me134
Re: Poor WiFi
Firstly, unplug the hub for 10 minutes and then reboot.
Have a look at the following to see if they can resolve your problem easily if no success with the above, you can also use the MySky app. If not you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used).
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
https://www.sky.com/broadband/wifi-max
Not a Sky employee
Sky FTTP 500Mb to Max Hub
